Recommissioning mk2 after 17 years dry storage
Hi everyone,
I managed to get a polo saloon for my brother to have as his first car. It's a 1987 mk2 saloon with 45,000 miles, full service history and even the receipt of purchase! The car has been in storage since 1997 and has only been brought out in the last 3 months. I'll get a few pics up when we get the car.
We don't actually have the car yet (getting a transportation company to deliver) but the guy I bought it from said he has it running.
So far the the seller has:
Changed timing belt
replaced core plug
new coolant
new seals on pump
new filter
I'm planning on replacing:
front discs and pads
rear shoes
brake hoses
brake fluid
oil
oil filter
oil sump seal
fuel filter
spark plugs
tyres
Is there anything else you would suggest I change? Should I be changing the fuel lines?
I know I'll have a better idea when I get the car but want to order as much as I can now so that we have the parts when the car arrives next week.
Thanks!
Shea.
  • Replies 11
  • Views 645
Check all the suspension rubber bushes for deterioration
rubber brake hoses for sure and carefully inspect the metal lines
bound to need some wipers too
other than whats listed id just run it on some local trips and keep having a good look over it each time to see if anything is leaking /failing as you go
If one core plug has gone, chances are there are more to follow.
I replaced a leaking one and while I was there checked the others.
They were just like foil milk bottle tops, screwdriver went right through them.
Really dont know how they held under pressure.
Replace the water hoses. I got a mk1 Golf cabrio back on the road after being sat for years and the hoses were all solid and cracking. I didn't replace them at first and was having issues with them bursting every week, one after the other.
Basically any rubbers are likely to need replacing. Bushes, hoses, fuel lines etc.
Thanks guys, I'll be sure to check those parts when we get the car. It turns out the fuel tank needs changed too. I saw that VW Heritage has some New Old Stock fuel tanks for polos but it says up to 1984. Does anyone know if it will fit a 1987 carbed 1043cc saloon? The guy Andy at VW Heritge seems to think it will.
Whip the cam cover of and make sure the cam hadn't rusted. Bar the engine over a couple of times in case a valve has got stuck.
An earlier tank will fit, but they hold a lot less fuel.
Thanks yeti, I'll get the cover off and have a look. VW heritage are doing New Old Stock tanks so will be good quality but hold less like you said. I'm not sure of the quality of the reproduction ones. What would you rather go for yourself?
i got a tank off ebay.de ...says 10 year warrenty but who knows lol
its lasted fine so far ...i think as long as whatever you buy you take some time to prep and paint it well it should last , then make sure you jet wash that area during the winter months
id recommend an epoxy primer for best results
The repro ones are generally alright, sometimes need the neck aligning to the hole in the panel by means of a broom handle down the neck.
Also check the tyres for crack etc, as these can be overlooked sometimes when a car has been stood for so long
