Clocks won't leave there home :(
Okay so I might just be being an idiot but I can't get my clocks out of the dash. I bought some radio pins off eBay and they fit all the way in but it won't budge. Any chance I've forgotten something or can someone point me towards correct pins so I can check mine. Thanks in advance.
  • Views 672
You don't need the pins, i just guess it would make it easier, but it sounds like your pins aren't disengaging the spring clips.
The way i do it:
1-Remove steering wheel (doesn't have to be done, but makes things easier if you've got the tools there to take it off)
2-Remove upper and lower steering colomn shrouds
3-Remove stereo
4-Remove drivers fresh air vent ('close' flap, shine torch in and philips screwdriver for a screw towards the top, put the screwdriver through the grill at an angle)
5-Release vent piping back into the dash, put one arm in the hole up towards the clocks and your left arm in the stereo hole towards the clocks, feel the clips, release them and push the clocks out (you need skinny arms)
6-pulls arms out (giggedy), pull clocks forward and release multiplug
Your keys should skip 3,4 and 5. They may not be long enough? But the above is a plan b.
sweet nice one dude i'll give it a go tomorrow
