Rolling Road Day 2015
Is this happening as it's not too far off and I've seen nothing? If it is happening, could do with posting it on all our medias to get the numbers up :)
  • Replies 16
  • Views 881
  • Yes it is booked it up this week. Just waiting for some final things to be sorted and then we will post info up :)
  • I'll be there this time around
  • I'd check the state of the cambelt (especially if it's coming up for the 40,000 mile renewal) and oil level and cooling fluid level before a rolling road session.That said you could just as easily bre
Sweet cheer Mark, just so we can push it on here and on the FB group to make sure the numbers are there! We could also wack it on MK1-3polos
sounds good! :)
I'll be there this time around ;)
looking forward to getting some details, been a long while since I've been along and actually have a car worth rolling this time round! Obviously polos are priority but will there be room for members' non polos?
Stupid question, but how tough is a rolling road on a car? I've always wanted to get the GT rr'd, but i am relying on it daily for a 70 mile round trip (my only on the road car), so the idea of it being thrashed makes me wince a little! I only take it up to 4.5k max.
I know i sound gay, but meh
We normally try and run:
Members with Polos
Members Non-Polos
Non-Members with Polo
Non-Members none Polo
However it does normally work as a first come first serve so best bet is to get there early (starts about 9am) and you are pretty much guaranteed a run :)
4.5k MAX!!!! :shok::shok: Poor little Polo give a bit of thrashing once in a while it will do it a world of good!!! :nod:8-)
We have been doing this for many many years and not once have we had a car go bang on the rollers (that I know of!). Granted when you are standing there listening to the car rev that much can be a little unnerving but its all fine :)
I'd check the state of the cambelt (especially if it's coming up for the 40,000 mile renewal) and oil level and cooling fluid level before a rolling road session.That said you could just as easily break down on the way to or from the rolling road as on it.
Good to hear Mark :good:
providing it's a weekend i'll be kipping at my old mans in Northampton the night before so i can get there nice and early.
Volkskid, from what i know of the guys that operate the rolling roads, they will be able to tell if the car cant take it and will back off. They have quite the acute sense of hearing and feel when it comes to pushing cars!.
Stuff it, let em red line mine :P
Going my luck it will be on its last legs again... Lmfao
Yes thats fair! The idea of an 8k limiter makes me cry a little inside, that said the previous owner had one fitted before i rebuilt it...
What i meant was is there a general rule to the rpm they take them to? The limiter or red line? And how long do they keep it there? I'll watch some rr videos when home from work and pay more attention.
I was thinking a full service say a month before the RR, the cambelts done about 25k. I know i worry to much but this things like my child!
I can't see the need to stay at redline for too long, it's not like your cars got much power up that end of the range! my old mk3 the peak of power was around 4k
So once car is strapped down tight and engine oil is warm enough and they have a reliable tacho signal for rpm the rolling road operator will do a roll-out run to calculate the losses due to rotating mass and friction. Then they'll go for it, pedal to the floor in 4th gear usually.
Looking at my dyno prints Novatech at the Polo show took it to my 6800 limit in 2011 and up to only 6200 in July 2013.
(that was probably fuel starvation - though they suspected air correctors too large).
They don't hanga around at high revs, becauise there's plenty more cars in the queue. Aldon also only took the car to 6150rpm in Feb 2013 (but did 3 power runs as it kept getting better as it heated up).
The only cooling is a large electric fan blowing at the radiator grill so engine gets hot for as long as it takes to reach max speed then they release the pedal and roll out. So it's a good idea to hold in in winter (colder denser air).
It's about the same stress on engine and driver as overtaking someone up a slight hill when you probably should not then not slowing down (or changing gear) in case they catch you up again on the flat. Anyone else feel embarrassed into driving quicker than they should in a lightweight car?
You do want the revs to cross the 5252rpm boundary to check the torque calculation is correct.
As no air resistance calculated top speed may be optimistic.
thats really good info dvderlm!
I've just had a thought, my caddy doesnt have a rev counter, will this be an issue or do they use their own?
They use their own to be able to give you a printout. Small inductive hookup to an ignition lead usually.
Aldon's last dyno used to have a big sweep hand gauge showing approx horsepower but it's all on a computer screen now.
its pretty scary , might not be for you if you baby the car
but then if a run at full power blows it up maybe it was gona blow soon anyway
