My 6N2 GTi is wetting itself!
Hi guys my screenwash is evaporating at about 2 litres over three days!! I have checked the seal between the two tanks and it seems dry. Both headlight washers operate properly I suspect the n/s unit but how to I get to it to check? I took the foglight out to have a quick look but cant seem to suss it?
  • Views 817
I had this problem (not VW) some time ago,
Headlight washers were syphoning fluid from the reservoir.
I ended up fabricating a small anti-vacuum valve which I fitted into the pipe - worked fine.
Regards
Thankyou caretaker, i will give this a try!
ps do you mean the sort of one way anti syphon valve you use in a fishtank? Also I'm assuming id need to put one per headlight washer as close to the units themselves as I can?
When you say it's wetting itself do you see he where the water is going.
Does it show up on the ground, in the car or in the tailgate ? (the rear wiper washers fail regularly)
Hi, pretty sure its the headlight washers
