*Help* How to smooth plastic bumpers?
Is anyone able to give me a guide on how to smooth plastic bumpers? (With pictures if possible)
Been seeing quite a few MK3 Polo's with colour coded bumpers and my god they look sweet!
  • Views 2.6k
Smoothed as in removing the texture or smoothing the indents and numer plate as in this
0098d80e888fe6d920fbe3eca52062d4_zps716c
Ah sorry, as in removing the texture so they can be sprayed! :smile:
work down the grades of sandpaper till it's smooth then use plastic primer then paint
I've just smoothed the texture out of my engine cover, took fucking ages!
I used a electric sander which probably saved a lot of time. I'd say start on 180+ grit, I used 80 grit and it just scratched the hell out of it! Make sure you sand every single bit of texture out before you paint because I ended up painting my engine cover 3 times before I was happy.
Nothing worse than wet sanding out what you think is orange peel and turns out to be texture :lol:
Thanks for your help!
Pretty sure a mk3 bumper can come with a primed bottom half as standerd ?
