Anyone sprayed textured exterior trim without smoothing?
Hi guys, was wondering if any of you have sprayed your textured exterior trim (rub strips, valances etc) without bothering to smooth off the textured surface?
If so could you possibly post some pictures of how it came out?
My Polo is a little bit sheddy at this point, and to be honest I cannot be bothered to sand them down before spraying them.
Regards. :smile:
  • Views 646
I haven't got a picture but some one had sprayed my 6n2's front bumpstrip without removing the texture. It looked like shit.
If you're painting them matt black to tidy them up it may look okay. But if you're colour coding them I wouldn't bother.
The only way that works is to use a vinyl dye rather than a paint, but that's not perfect and you will need to degrease first.
You don't need to sand them completely flat, just to get a good key on the surface.
You then clean it well, and use a thicker primer after a coat of adhesion promoter. Then depending on how flat you spray it you should only need a quick flat down to get any runs etc out, then on with the paint.
I have done this on a gti splitter, but at the paint stage I used textured trim paint, a little pointless to some, but this way it is completely flat with no dings and looks like a new one :)
