Hi guys, i've got to do someone's front end on a 6n2,and he just wants to know how do you line the bonnet catch up? Is there any special way?
Also to remove the slam panel how many bolts are they? had a quick look on mine and can see 2 torx bolts and obvious ones for bumper reinforcer? anything else i should know?
And how do you split the rads off the slam panel? ordered a brand new one for him :)
  • Views 846
Ones the bumper cover is off, there are the 2 torx bolts above the head lights, and 4 13mm bolts at each chassis leg. Then the whole things falls off.
The radiators are bolted on from inside, 10mm bolts. The fan is also bolted on. If it has air con, then the air con rad is bolted from the bumper side, again 10mm bolts.
With the catch, I tighten the bolts up tight, then slacken off slightly, then shut the bonnet but dropping from about half way. Then open it again and tighten it. You could also bottom out the adjusters at each end, and adjust the catch to close when you drop it, then pull the bonnet up a little (when the bolts are slackened) then tighten it and adjust the rubber stops back down again.
There are many ways to do it, but mainly I would say just make sure you don't tighten the bolts when the catch is all the way down, because it may not open again.
Hi, Yeah seen its got 2 torx bolts at top, dont sound to hard!
Ahhhh sweet! and i dont think it has, its a 1.0 lol
Sweet! was thinking of something like that!
:) thanks
Cheers! worked perfect! :D
