Painting new fuel tank
Just got an ATP fuel tank. I've read that the repro tanks should be repainted and stone chipped so they can last. Just wondering can I just key the tanks paint and paint it in POR15 then stonechip or do I have to take it back to bare metal.
Here's the tank
Thanks!
  • Views 729
Just key it 👍
up to you , if you key it then what you paint on will only stick as good as whats already on there
personaly i dont like por15 and its not sposed to be used over keyed paint anyway ....id go with a epoxy primer
I've had really good results using Bonda Primer on bare clean steel by brush, then a coat of gravitex followed by a coat of either body colour or semi gloss black. It sounds excessive but really protects the tank. Use the same 'system' on all of my underbody repairs for the last eight years and no problems yet.
Yeah I'm inclined to agree - I'd use something like Expoy Mastic from Bilt Hamber... Superb product.
http://www.bilthamber.com/epoxy-mastic
The tank looks like it's already painted top coat, not just carriage primer. I'd just key the paint then wack on some hamerite with a brush.
That what I did with my tank at least, with stonechip on the filler neck too.
I roughed mine up and gave it a few coats of por-15. Brushed it on and it dried to a glass like finish. That was three years ago and still looks fresh. Id only recommend black though as the silver is very streaky.
Did mine in bright blue and brown :lol:
