6n wind deflectors - how to fit?
Hi all, I got a pair of wind deflectors for my 6n off a breaker, however I have no idea how they fit and they don't even know what car they came off let alone how to attach them :)
Do they just slip under the rubbers? Or are they glued or clipped to the outside?
I got a similar set for our Toyota a while back and they came with clips and fit the outside of the door, but they didn't give me any clips etc with the polo ones.
Any help ?
  • Views 811
Put your window down mate and then slot them into the bit where the window goes up into if you get me? Then make sure your window goes up all way :) hope this helped :)
When I got mine new you get little clips you push up into the rubbers then push deflectors into them, with how tight they are in there I don't think you would even need the clips so you should be alright
Thanks guys,
So no clips are needed? From the pics that come up on google I don't see any on any of them, so I guess I will be fine. Loosing them isn't my main worry, it's the people behind getting hit by it in high wind :)
Mine dont have clips in and mine are fine mine, they're pretty tight in the window bit so i wouldnt say they would fly out :)
Mine are fine without the clips too. If it's a 5door however don't let anyone open the rear windows when driving.
