cracked/bent/rusted front corner help mk2 bready
Hey guys, I took my front bumper off of my 86 Breadvan today to spray black as it was faded grey and shitty, and I found on the lower right portion of the front end the metal work is bent out, paint cracked and rusted. I know it's hard to tell without seeing in person but I took a picture. You can actually see where it meets the front quater the bottom doesn't line up.
This is actually the worst of the car, in general it is in good nick no bad rust anywhere else apart from the bottom of the passenger door, and a few various chips in the paint .
Does anyone have any advice? Would it be a case of sanding down, re shaping, rust removing and re spraying or maybe something more serious?
I don't think the panel can even be changed as its attatcched to the engine bay/ body shell.
post-918676-0-30799000-1415548147_thumb.
  • Views 666
yeah should be able to clean it up and reshape it to a decent standard
fyi they can be replaced , but by drilling off the old panel and welding on the new , so not a diy job for most
That's great, cheers bud. I was a bit worried as it looks as though it's had a front end ding sometime in past and thought the problem may be more serious, though upon closer inspection i'm pretty happy it's just cosmetic damage. I think I'll go with reshaping it when it comes to spraying the car. Nice one.
