Aircon - or not?
I'm doing a pile of work on our 6n Open Air..... (full length fabric sunroof)
Complete engine, 'box suspension etc is all being transplanted from an unwilling donor.
Do I also fit the aircon? I'm hoping not transfer more than I need to and Aircon would mean that the entire front looms would also need to be swapped.
The engine I've taken out has a couple of minor differences I hope I can get round....
I'm just wondering if:
a) It's worth it bearing in mind it's an Open Air ?
b) Will it add a significant value/desirability if/when we come to sell?
  • Views 909
I'd say pointless if you have a open air but if you want to you will need:
Pump
Bracket
Wiring
Hester matrix
Pipe work
Condenser
Evaporator
Rads + mountings
Temp sensors
Then need to wire it all up INCLUDING wiring to your engine ECU
All the parts are available on the donor car.
I'd need to strip the dash more than it currently is, but as you say the Open Air probably trumps A/C.
- unless it adds significant desirability.
I'm sure it will add desirability but enough to warrant the amount of work needed. I would say it could be easier making the donor car an open air! :)
I must admit I've been thinking of how to air condition my mk2
To change heater matrix you would need to fully remove the dash. I was going to AC mine but it's a lot of work so instead I cut my roof open and fitted a open air
Just my opinion, cos we had a mk4 open air for more than 10years in our family, A/C is much more comfortable. I never liked the roof cos it was always windy in the car. You cannot drive quickly with complete opened roof. Also the noise from outside comes in, opening the roof in the rain is dumb, but in the rain you can use the AC.
It was my parents daily car, they have never used/opened the roof. Now they have a brandnew 2014 polo with AC.
The roof makes also a lot of trouble, we had to change he whole roof and the rubberseal around it back in 2004, see:
http://www.vwpolo6n.de/christian/2013/05/30/austausch-openair-dach-2004/
and as you can see on the pics in my blog, there is not just a hole cut into the roof, it is a bit more.
AC you can convert into your polo so that you cannot see whether it comes from factory on or not, see example mk4:
http://www.vwpolo6n.de/christian/2014/07/23/original-nachruestklimaanlage-vw-polo-6n1-und-6n2lupo/
here you see how much work it is....
@Mark, on last Hamburg Poloshow a couple of months back someone with a mk2 derby told me he has got an AC for that car but he has no injection, so in case of converting that AC into his mk2 derby, the engine would die when the AC compressor switches on.
For your car you would need half of an mk4 AC...... ouch you also don't have an ECU, right?
Hahaha sorry i didn't said anything..... there is no chance for an AC in your mk2 i guess.
Keep on dreaming, there is no open air roof comparable with that:
cheers
Christian
Hi Christian.
I've got an entire car already fitted with Aircon and ABS (& obviously an ECU) that I am taking parts from.
It's a matter of whether the marginal benefits (in this country) justified the effort and expense of running it.
As we've had a 6n2 Open Air with Aircon before, the AC was hardly used.
I've therefore decided not to transfer the AC, though the decision not to transfer ABS was harder.
To my knowledge, the non AC ECU (and for that matter ABS ECU) is the same - it's a matter of how it's configured.
Regards
Muddi
Yeah that is the problem. But I've been thinking of trying to find an electric compressor.. so its still a thought in progress :)
