1990/G Fox Breadvan Breaking.
All parts available.
Car is red, 1043cc, four speed.
Contact for anything you need. Postage and PayPal not a problem.
Based at IP25 Norfolk.
Example prices, all cheap to clear......
Steering wheel-£5
Grille-£10
Parcel shelf with speaker holes -£5
Dodgy red & grey seats, need a scrub-£5
Happy to cut panels out.
  • Replies 62
  • Views 3.2k
pm sent on shelf and shelf supports please
Distributor please (posted).
Distributor on its own or with the coil and amp?
Is this the facelift bread van mk2f or the earlier mk2?
If it's the facelift I might be interested in the front wings as I'm just down the road (sort of!) on Ipswich ;)
This is the style I need
Do you have the drivers side door foil? The thick plastic film behind the door card. Is it in perfect condition? If so how much posted?
I've yet to take the doorcards off, but Il get back to you when I do.
Cant imagine posting would be as awkward as taking the buggers off!
darknights-I went to Ipswich once, but it was closed.
Its a MK2 G reg as stated, I do have some Mk2f specific parts, but not much.
How much for just the dizzy and how much for the lot? Nice to have a spare I guess.
One like this:
Also how much for the starter motor? Think mine might be on its way out.
I'd like £75 delivered for the dizzy, amp, coil and loom. I'm not splitting them as its a full package for an engine conversion. Starter motor is £5 but p&p will be the killer.
What steering wheel does it have?
Alright, nevermind :)
I only really need the bit pictured and £75 is way too much to justify it.
The foil behind the cards are plastic sheets so they shouldnt be difficult to post. Also do you have the cap that goes over the rear wiper arm nut number 4 on this diagram
post-15736-0-15052600-1416770922_thumb.j
Edited by c.w.pritchard
Cheers mate ;)
Have you got the push is coolant pipe that's at the back of the engine ,the one behind the water pump? And the bolt in breather at rear of engine
I've got the coolant pipe, do you have a pic of the breather you need?
Passenger side glove box?
Pretty sure I've got a Glove box.
£25 delivered.
PM me if interested.
You mentioned your happy to cut panels out? I'm after the drivers side rear quarter (from the b post to the mid rear arch) if possible?
Its possible.
Its got a bit of rust on the edge of the arch where the tank was leaking and a small dent below the window, PM me if interested.
Edited by oldeboi
Cool ,it's the one on the back of the block that the rubber hose connects too ,I'll take a pic and send it on , how much sent
Ok Kano,
PM a pic and Il see if I can help.
Are both doors rust free? If so price for pickup?
Doors are in very good shape, couple of scabs but easily touched in. £25 each.
