1990/G Fox Breadvan Breaking.
how much for front calipers? are they in working order? they VW1's yeah?
  • Replies 62
  • Views 3.2k
Any luck with the front valance screws?
Sorry prank, I meant to message you.
I've managed to find three out of four so far. If you want to hang on for the forth, or I can post out the three if you cover the postage?
Calipers are good working condition.
£15 plus p&p/fees at cost.
hi there,
Could you please get my a postage quote to DD85NL for the calipers please!
Also I can pm you so got a phone number?
Hi, I'm after the balance weight from the drivers side drive shaft, it right in the middle and clamps on with two bolts?
Hi mate tried to message you, think your inbox is full, I'm after gutter trims, fuel pump, cigaret unit if you have any of them? Cheers
Not heard back from the guy in ages:/ anyone got his number?
*****INBOX FULL******
Hi, I'm after a rear number plate light and door rubbers please?
Hi mate do you still have the shell?
I need a section from the drivers rear quarter that includes the rear sill area and beam mount.
I've tried to pm you but your inbox must be full.
hi, am do you have a pierburg carb?
Do you have the front section of carpet. Its for a mk2 bready and its the grey I'm after
Do you have a full lock set including ignition barrel with two keys?
How much posted?
