085 CEG gearbox - 5 speed
085 CEG gearbox which has the same ratio's as the 8P box but has a bolted crownwheel, unlike the riveted one on the 8P. This means you can fit an LSD to it if wanted. Both mounts and starter motor included if wanted
£60 collected from Rugby
  • Views 919
Hello, not sure of what codes are what ha, is this a close ratio 5 speed for a 1.3 gt? Or just a 4 speed box?
The CEG is a late spec equivalent to an 8P and will have the same ratios.
It is a 5 speed, a lot of the g40 boys favour the 8p and CEG if they can't find a ATV
There is a thead on here somewhere with al the ratios
8p/CEG
Final drive 4.063
1st 3.455
2nd 1.058
3rd 1.250
4th 0.891
5th 0.740
Okay so it's basicly a gt box? My box in my gt has had new gears put in not sure of the ratios but 1st 2cnd and 3rd has a higher output so I'm guessing simalar to this. It will fit a mk2f gt won't it? Also if there is no wines or anything I will have it pal
Not sure what the GT box ratios are so can't comment whether it's the same. I think 5th is longer then the GT.
Yeah box is fine no whines or crunches
PM me if intrested
Rich
