EuroCarParts Pattern wings mk2f - Anyone tried them?
As above, have anyone tried using the pattern front wings for a mk2f polo coupe from euro car parts?.....
i've got some significant surface rust on both of mine, and thinking it may be easier to buy 2 new solid ones for £68, rather than faffing around trying to sand/fill/paint match sections of the OEM old ones?.....
any thoughts apprecieted :-)
http://www.eurocarparts.com/ecp/c/Volkswagen_Polo+Coupe_1.3_1991/p/car-parts/car-body-parts-and-car-exhaust/body-shop/body-panel/?802440581&1&5319aac7cdc8cfaa04ea8d63ea87ce4372c7d8cd&000375
  • Views 1.7k
As with any pattern panels, they will no doubt need slight work at the edges, ie bending and maybe a little filling. To get them flush with the other panels.
I would be inclined to use some kind of rust proofing on the inside. The metal will no doubt be a lot thinner and no where near as good quality of the originals, but if sealed from the elements will last a long while.
From past experience and through a friend who does body work you spend more time making the thing fit properly and not the best of quality either
If they are "Klokkerholm" made panels then I have helped a friend fit a pair of those to a mk1 golf and I was really surprised at how well they fitted. Yes we needed to oval some of the mounting bolt holes but nevertheless, pretty damn good for a bandit panel.
That said we had a classic Mercedes coupe that needed both wings, got them from Eco and they were brilliant, almost the same gauge as the original and bolted right on with no work. I forgot about that.
May well be the same case with these, but best to approach them with the expectation that they will need work to fit.
