6n2 gti running fault
Right my 6n2 gti has a fault that only happens at about 4k rpm in 4/5th gear..
it jugders and then the revs flat line.?
anyone had this?
  • Views 457
Have had the fault codes read? as not all will put the warning light on
When you say flat line does it cut out , what is the engine code arc or avy and what year is it
