Fitting Momo steering wheel and Boss
Hi, Does anyone know which wires are used for the horn etc.
I have a resistor which is obviously for the airbag light but there a 2 black wires and 2 red wires, but a local mechanic told me i only need one of each,
bit confused now, any help would be much appreciated.
  • Views 811
for what car? they differ between models and be aware that the removal of an airbag is now an MOT failure and thus a potential problem if you are stopped by the police/vosa
If you remove the airbag make sure you atleast take the bulb out which shows airbag on dash then wont be a problem for mot
Edited by theLEGENDofBURT
theLEGENDofBURT - the forum rules are clear - dont give out duff advice! so if you dont know the MOT regulations you should not be commenting.
You will find that if an airbag was fitted to the car from the factory then it is required to be present for the test. So removing the bulb will not do that will it!
I am well aware of the mot regulations and seeing as i am a mechanic and do take mots i know providing no air bag light lights up you can get away with it. I have done this to my track which i mot`d last month and friends and customers car for various reasons have removed airbags and not been a problem this year.
well you should full well be aware then that the test states in section 5.4 under supplementary restraint systems - reason for failure No1 is a missing airbag. Just because you do it is not just enough reason to suggest to someone else that it is ok to do if you remove the bulb.
The original poster may find that if he is stopped by VOSA that his car has no valid MOT and is taken away AND if that invalidates his insurance he may find the points on his licence counting up.
As much as many people bend the rules it is not right to post up duff information.
If its all ok in your eyes put you garages company name up on here with an address and phone number and we all know where to go when we need a bent MOT.
I can assure you nothing bent where i take the mot's. For instance if you took a car in with a factory steering wheel missing airbag then yes it will fail but if you have a aftermarket wheel fitted then you will find it comes under one of many loopholes in the system
I didnt think you would name the garage.
We can leave it there.
