Late 6n and golf mk3 clocks the same ?
Just wandering if there the same need some clocks for my 1999 6n code as can be to 110k
  • Views 731
nope, only early 6n clocks are the same
They are a different design, with a different connector on the rear.
That said though, they might physically fit and you should be able to rewire the connector if you fancy it?
Edited by R10tz0r
As above the early ones are similar.
Kufatec actually sell conversion looms for this, so should be doable if you have the connector.
Edited by dixy
