Rear Windscreen Washer - Pipe Leak?
Hey everyone!
Currently not getting anything out of my rear windscreen washer.
The front one is working fine and I can hear the motor running okay when I press the button, so had a check under the car while the missus was pressing it, and I notice it dribbling out of the underneath of the car between the front and rear door on the passenger side, so I guess the pipe has become disconnected or has developed a leak or something.
Can someone point me in the right direction for where this pipe runs and how I can get to it to inspect it?
Or a common place for it to come disconnected and how I can check this?
Thanks!
  • Views 2.1k
There is a production break in the pipe on the passenger side, rear seat upper seatbelt mounting point, it popped apart on mine and the fluid was collecting in the spare wheel well, others have reported it in the rear seat footwells so that's the area I would start looking
Thanks nige!
Forgive my naivety, but how would I look at the break at the rear seat upper seatbelt mounting point? Can't see any way of looking at it from the front so I guess it's a case of getting into that bit of the bodywork from the rear, there seems to be a seal around the top of the boot - do I remove this, does this give me access to where this break is?
I'm not nearly as brave with the interior/bodywork as I am with the engine, so forgive me - I understand that's most definitely a stupid question...
You need to remove the trim between the parcel shelf support bracket & the upper seatbelt mounting bolt, once the support bracket is removed you should be able to pull the upper trim clear to see the pipework
Great, thanks nige, I'll have a go tomorrow! :-)
