86 mars red breadvan
Astounding rust-free 60k example, just been smacked against a kerb so hard it bent the passenger door frame.
Currently driveable, good engine, so take trim and panels or make it worth a grabber.
Pm me please, I won't check this topic often.
  • Replies 18
  • Views 1.2k
Your PM full mate...
would you sell car as a whole?
Oryt buddy were bouts are you poss interested in few bits
Rear bumper and steering column cover?
Sorted.
Possibly, mail me.
These will be available so long as the whole car isn't sold, I'll give just a few more days before I start breaking it.
More on the damage - it's hard to find any mis-shape of the passenger door frame, but the gap between door and B-pillar is tight. The gaps are consistent all the way along but I'm convinced the door has moved.
The chassis leg has a bend in it at the gearbox end plate area, it's not kinked, it'll probably pull out. But I'd wanna use a subframe if saving it.
Just to confirm, it is now breaking.
Cam cover gone (replaced with a steel one).
do you have the heater matrix? Able to post to York?
Hiya mate, do you have the passenger side trim between the front window and the back window?? On the pillar, the ribbed part?? Thanks
Yes, and yes.
Message me.
What engine is this?
Late MK2 1043cc carb (one of the first examples, 1986 spec)
I don't know the engine code, haven't got new logbook through yet.
4-speed gearbox
would you strip the cloth off the rear bench if its the same pattern as the front seats? just need the cloth to recover mine cheers Malk
Have you still got the dash all in tac?
Hi Mikey, Does it have a good early bonnet? Mines rotten underneath like a peach.
How much for both wings mate?
parcel shelf? dont mind if its cut
Mudflaps please
Car has now gone, nothing available.
