GT CLocks in MK2f
Hi
@retrowheels kindly sorted me out with a set of clocks with a rev counter :D
now i was wondering if anyone knew if this is a straight plug and play swap or if i will need to do anything to get the Rev counter working?
Jay
  • Views 1k
  • kwijibo_coupe
    kwijibo_coupe
    Straight plug and play. I'd swap over the speedo part so you keep the mileage correct but apart from that it is simple. I know there is an issue with early clocks in late cars or the other way round
I know there is an issue with early clocks in late cars or the other way round which effects the oil pressure buzzer, but just plug them in and see.
haha i had a fiddle when they arrived and saw that i could change that over, i dont fancy adding 30k on overnight!
It had 70k on the clock so hopefully they are late clocks.
J
Unfortunately they must be early clocks.. as soon as i hit 20mph the buzzer starts going and the light starts flashing.
Is there a fix for this or is it a case of selling the cluster and trying a different set out?
the buzzer is to do with early clocks and late clocks having either 1 or 2 oil pressure sensors (cant remember which way round, but think early has 1 sensor for High/low, where as late has 2 seperate sensors for High/low, hence why buzzer sounds most of the time) hope that helps. there is several ways round it
