Maxmax's black Supercarbed G40
Itll all be finished in time, dont you worry nigel.
  • Replies 45
  • Views 3.9k
  • Itll all be finished in time, dont you worry nigel.
  • Not much progress on this lately, Started machining up the parts for the adjustable TCA's The hole in the center has now been opened up to 30mm to allow fitment of a bush assembly, i've dr
  • Yes mate, the signal wire is cut between the hall effect sensor and ignition module. Literally the easiest thing I've ever had to wire up, and showed really good results even when I was running the e
lovely car.
Few updates, got the front aluminium brace done - intercooler and radiator will be mounted to this.
Also started knocking up the fixture for the adjustable TCA's, going to see if i can convert the ball joint to a rose joint too so they'll be a 100% fully serviceable component.
I've also started to attack the rot on the front turret, began carefully cutting out the effected material
Finally got down to the source!
Edited by MaxGT
really going all out... love it!! :)
Cheers mark!
Yeah its good to get stuck into something again!
How noticeable was the rust on the suspension turret? As it seems there was quite a bit to cut out.
It started in the corner mark, where it had totally rotted through, but then the surrounding material had badly pitted and "thinned, so cut that out plus 15mm around it to make sure it had all been removed.
I'm more than likely going to be adding a few small gussets to the front of the turrets to make sure the strength is adequate, as well as fully stitch welding the engine bay.
Nice work Max - enjoying seeing your progress!
Cheers mate. Broken hand its stopping progress now though :(
Interested in your rose jointed TCAs
The bush where the ARB originally goes through the TCA will have to be moved inwards slightly to accommodate the extra length of the thread on the rose joint.
I've done stiffness calculation on a round 18mm cross section (rose joint thread) and the cross section of the TCA between the ball joint and bush - they were very similar. Still in the idea stage anyway!
The hole in the center has now been opened up to 30mm to allow fitment of a bush assembly, i've drawn up a quick model of them, though haven't got round to ordering the components for the hex adjuster and rose joints so these aren't in the model yet...
Also knocked up the rear mounts for the subframe out of 2.5mm steel
Looking good Max cant wait to see it again at RR day !
It won't be making the rolling road day I'm afraid lol, its in a million pieces!
My post #25 :-(
Right, here's a few pictures for Jake :tongue:
Pretty much everything off it apart from the passenger side door and tailgate.
Also started work on the charger, was last rebuilt in 2006 as a stage 4 by jabba, so due a rebuild for sure, was boosting a supposedly 0.8bar on a standard intake system however!
Before it was ripped apart
Timing belt cover off
Scroll out
Very grimey inside!
Pulley side, scroll and outlet side into the ultrasonic bath for a pre-wash
Getting the outlet side ready to go into the media blaster, used soft glass beads to treat it
Came out ok, a lot of aluminium discolouration after 20 years or so!
Will be doing the rest of the bits and then ordering the rebuild kit when i've got some spare money!
Also started on the new carburetors for it, they've already been in the ultrasonic bath, so just a case of checking them over and putting them back together...
Plenty more to come!
Liking the attention to detail!
Looking very tasty Max! I hope to see it at the Polo Social ?
Lol, possibly.
A lot of work to do!
  • 7 months later...
How are you getting on with this Max?, missed you at the Polo Social somehow?
