Replace standard bulbs with SMD LED
LED relays - will these work on a mk3 (2f) Polo?
http://www.ultraleds.co.uk/complete-led-flasher-unit-stops-fast-flashing-led-indicators.html
£15.31
http://www.autoelectricsupplies.co.uk/product/726/category/35
£11.08
The first one states all your indicator bulbs have to be LEDs, the second states it's happy to work wit a mixture of incandescent and LED
Edited by schneil
  • Replies 31
  • Views 2.8k
  • http://www.ebay.co.uk/itm/VW-BOSCH-1197311028-ALTERNATOR-VOLTAGE-REGULATOR-NEW-068903803-17202-101506-/291221247920?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43ce2397b0
  • If you fit LED's into the indicators, you need to fit a resistor into the wiring otherwise the very low current used by the LED's will cause the flasher unit to flash at a stupid/illegal speed
I think they are brighter. Yes replaced all except indicators. Try a set on the rear side lights. Pretty cheap. Compare bulbs with led.
Ok cool I'll get some :)
Edited by schneil
Be carefully not to catch the smd's when replacing the bulb holder. Bit of a fiddle.
Hello
Well I tried the bulbs you reccomended. They're OK for tail lights (even though they look slightly less red)
But they are a lot dimmer than the standard 382 21W bulbs
LED bulb
Standard bulb
That looks pretty conclusive.
If you get some 21W equivalent ones, let me know.
I'm hoping in the near future they'll have "filament LED" car bulbs available.
Here's one for the house - it's a 40W equivalent
http://www.screwfix.com/p/sylvania-gls-led-gls-lamp-bc-4w/6334f
No issues with beam patterns
That would be immense.
