New seats trim parts and advice required - Golf Mk3 in Polo 6N
Hi all, I recently bought some front seats out of VW Golf Mk3 VR6 to put in my 6N - the seats are in good condition and I'm happy with them but one of the lever surround trim is missing so I'm looking to buy a replacement, can anyone advice the right part number for this small bit of trim?Also the lever itself is also not affixed the metal lever in the seat, it slides on and operates fine so I think a bit of super glue to hold it in place will do the trick once I get the new surround trim in there, what do you guys think? Will the new surround trim click into place?
The one in the ebay link below looks ok but is definitely not the same judging by the picture, the one I have has a dimple at the top and two parallel lines at the bottom (obscured in the picture but you can just about see one).
http://www.ebay.co.uk/itm/VW-Golf-MK3-Recaro-Seat-Lever-Suround-Trim-/331052431269?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d144337a5#vi-ilComp
The other issue is the small piece of trim on the outside seat rails next to each door, I'm missing one and wondered if anyone has a part number for that so I can get a replacement?
Thanks for reading!
Michael
Edited by michaeldc
  • Views 3.8k
Trim part number 191 881 607A #48 in picture
Seat rail trim
357 881 087 01C Satin black Left Inner
357 881 088 01C Satin black Right Inner
Outer covers it's shown on the diagram but no part numbers listed ??
post-36925-0-79151400-1419333395_thumb.p
Thanks nige, I edited my post while you were typing as I made a mistake, my inner rail covers seem fine on closer inspection except perhaps for the drivers side one which could do with replacing (I presume that's the right side one), but one of the outer end pieces is missing. Is the seat rail trim outer cover just the small piece? I need one of these (drivers side) and I should be set for the rails.
Re: trim part number 191881607A - I'm thinking I might not be able to find an exact match for mine so might take the other one out and get a new set, one for each side.
Edited by michaeldc
The end caps part numbers
3A0 881 347 01C End Cap Satin Black Left
3A0 881 348 01C End Cap Satin Black Right
You can also replace the 3A0 with 191
The lever trim pieces 607A are listed @ 2€uros ea so probably a fiver by the time the UK stealership has added their bit!!
Inner trim covers 3.5€
End Caps 3€
That's great nige! Where did you see them at that price?
End Caps 3€
Also, don't suppose you know if the end cap and inner trim is the same on a 6N2? There's a breakers 20 minutes drive from me with a 6N2 but no 6Ns so don't want a wasted trip if I can avoid it!
Exactly the same part numbers for both models :)
Cheers nige!
