MK2 SD cage
Hi everyone,
I know a few of you run cages, I am currently in the process of fitting a 6 point SD bolt in cage in my mk2 saloon and its not all that easy.
It doesn't want to clear the sunroof mech, as a result of this the rear section of the cage is not quite sitting on the arches. How have you addressed that issue? Some sort of plate to keep the sunroof shut?
Also any pictures/info on the weld in mounting points would be great.
Can you still get the seat in and out of the runners ok? It looks like the middle mount might make that pretty difficult.
Literally any useful info or install pics would be appreciated.
  • Views 741
the cages dont normally fit with sunroof cars.
Cant say the seat problem has ever arisen, this is due to it either
A - not being a problem
B - People weld in bars and fit seats suitable for a 6 point rollcage.
If it is for track use then i would fit better seats, if it is for road use then your in for a good time ringing up insurance companies for premiums - lots expect you to wear a helmet because of the cage. i only have a half cage in my car for that very reason.
I see, is there a way of blanking the sunroof mech without cutting parts off?
I am not sure that the seat issue will definitely be a problem. But it looks like the weld in mounts come quite close to the end of the runners, which might not leave enough room for the seat to come off the end of the runners.
The car is a road going track day car and I am currently running bucket seats which have been fitted to standard seat bases which have been modified. That's why I would like to keep the standard runners in a usable condition.
if i were you i would investigate insuring the car first before you put the cage in, you will find it is not as easy as you may think.
You could modify the runners to enable you to remove the seat 2/3" further up the runner if you sit with your seat far enough forward.
got it covered with greenlight and already agreed the cage.
adrian flux will insure full cages, got one in mine
