6n will corsa b sport banded steels fit help please
Hi all
My friend is selling a set of corsa b sport steels banded
Spec is
14" 7"fronts 8"rears et49 centre bore is 56.6
So I know center bore will need opening to 57.1
But how will offset fit will I need spacers etc?
Or can I get spacers they will a just the centre bore
Will I for in the rear arches ?
What size tyres would you use?
Cheers for the help
  • Views 1k
No one tried this or know if 7&8j et49 will fit
They're not et49. They were et49 before they were banded. They're not anymore.
You should be okay, it depends on their original width but valver alloys are et43 and Vauxhall wheels do tend to fit without fouling suspension. Plus you'll have less intrusive tyre wall than a factory wheel by more than that amount. If i was fitting banded wheels (or better still, replacement outer rim wheels) I'd use Vauxhall wheels to do it.
