What to look when buying a polo?
Hey guys,
My mate is looking to buy a 1.2 Polo (2002/3 model it think) soon and before I drive him round to look at some, i'd like to know exactly what to check for in a quality specimen.
Rust, exhaust, engine running fine, electrics are a given but what else should be taken into consideration?
(P.S If anyones selling a weber for a 1.3 Polo/Golf, message me ;) )
  • Views 592
That engine has a known problem, it eats valves causing a misfire, so if you can, get a code reader on it and if there are any fault codes relating to misfires, you need to get a compression/leakdown test done before you buy as it can be an expensive repair.
Rust shouldn't be a problem as its a galvanised shell, but if its had a poor repair then you might get rusting
Electrics not normally a problem area
I've heard a few horror stories of those engines throwing a rod at around 50k. So listen out for any bottom end clatter and make sure all the oil service intervals at least have been met.
The front wishbones on those also have a habit of eating the rear bushes.
Apart from that just the usual used car wear and tear.
Squeaky and rattling dash. In mine at least. If the bushes do need replacing as highlighted above, I'd recommend getting poly bushes fitted. I've had to have mine done twice in 2 years, so its worth the initial outlay.
Probably the best advice is go for the 4pot.
