Drivers side electric window not working
Hi hope someone can help me but I've got a 1996 polo 5 door and the window motor doesn't make any noises or anything when using the button, passenger side works fine. Also the electric mirrors don't work so could it be the same issue?
  • Views 717
Popular Days
First Welcome to the forum.
The most common problem for all door electrical faults is the wiring inside the flexy rubber tube between the door & bodyshell and especially the drivers door (gets opened/closed more than passengers side) the wires break, undo the big plastic nut on the bodyshell side and pull the rubber tube back and you'll almost certainly find a few broken wires,
