1.0 6n2 grinding at start up
I have just put another engine in a 1.0 6n2 after it sat off the road for 2 years and I have a teething problem.
When I start it I get a grinding noise for a split second and I am not sure what it is. My Alfa made a similar noise at start up and that was the variator but the AUC engine doesn't have a variable camshaft but that was the same type of noise.
You can listen to it here https://drive.google.com/file/d/0B6MeKYKDpRgCM3R1UVVfRTNSTDQ/view?usp=sharing
What do you think the noise might be?
Thanks.
  • Views 845
100% starter motor. Mine was the same just put a new one on
That would make sense because the starter hasn't turned in 2 years so I bet it has started to stick. I will have a look at the weekend and post an update.
Thanks for taking the time to reply.
a hammer tap is usually all is required to bring it up to speed
When mine done it i did try to open it up but isnt one you can take apart. I did put some grease on shaft which quitened it down abit
You can split them but little point.
As above a little tap should free it, but it sounds like the bushing is worn. Very cheap to get a new one on eBay.
I haven't ever fitted one on the car so can't help with that. I can say that if it is worn it will very cricklewood eat through any new starters spindle, making it scrap.
Starter motor combined with a worn bush that sits in the bell housing for the starter shaft
Exactly the same problem on the 1.8 20v, 1.8t 20v and 2L 8v VAG group cars
