BREAKING MK2F POLO (1993) All parts available
  • Replies 43
  • Views 3.1k
  • Do you have the drivers side door seal? And is it in good condition? Did you have any problems with leaks from it? And do you have the two (drivers and passengers) triangle bits of plastic that cover
text you :)
Dont supose it got 5 speed box?
No mate, unfortunately it's a 4 speeder
Wer bouts in leeds are u buddy what condition are wings n doors in cheers
I'm in Horsforth mate, ls18, wings are in good condition, very slight rusting on front corners, doers too are good, are you wanting Dort handles too?
how much for the carpet
£10 bud
And do you have the two (drivers and passengers) triangle bits of plastic that cover the wing mirror screws on the inside of the door? All clips in tact if possible.
If so how much posted? Thanks.
Edited by Sammy.
What's the windscreen like, any chips/scratches/etc? And how much for it?
Drivers door is worn at bottom, loads of cracking, no leaks however, doesn't look all that bad, will send pics toms, £5 plus postage and mirror covers £5 for both plus postage, will do bundle postage
Windscreen is in perfect condition, £30
If I remove it, seal will be cut out to avoid breakage
I will leave it for now, thank you for replying though!
No worries, you did the same for me!
Awesome, I do want but have to wait till the 14th before I know for sure if I can get it :-( will get back to you asap
No worries mate, i shall await your reply :good:
Passenger side Driveshaft needed, any chance you can lay your hands on one?
Yeah I've got one
Do you have the cover for the nut on the rear wiper arm? Number 4 on the diagram.
post-15736-0-43046700-1421617194_thumb.j
I think so, will have a look when I get back, away until Friday now
Looking at the photo. Is it complete? Mine has the piece broken that covers the hinge on the arm. Does yours?
How much for the rear lights posted to Ipswich? Are they genuine smoked late g40/GT ones or have they been sprayed? Cheers
Sorry mate, don't know which piece you mean
They're the g40 ones, and £40 posted
Have you got the 2 relays that are next to the ecu? I believe one is for the fuel pump and the other is the manifold preheat.
price on calipers posted? Working order? Only need calipers themselves no pads or carriers.
Hi, I'm after the balance weight from the drivers side drive shaft, it right in the middle and clamps on with two bolts?
