Clutch pedal
High been driving car loads over 300 miles in 5 days 4 days into it the clutch pedal seems to be squeaking every time I push it and seems to be a bit stiffer to when I started to drive it around has anyone got any ideas to what it might be
  • Views 504
Popular Days
A couple of possibilities come to mind:
(1) The clutch cable needs changing.
(2) The 'pedal box' (brake and clutch pedal mounting arrangement) may have cracked. - To check this, you need to get your head and a torch in the pedal area, you can normally see any cracks in the metal.
Regards
