My car makes a knocking sound when I turn, what could it be?
My car is making a knocking sound when i turn, what could it be?
  • Views 668
Driveshaft.
usually outer cv joint wear
outer cv joint
the best way to check to find out which side it is go to a empty car park and turn steering wheel on to full lock to the left then full lock to the right while driving and you will hear the sound that will tell what side is at fault and replace it
