A little help with rear calipers - 6n2
In need of a little advice.
I have gone a little overboard ont the brakes, I have striped them down and they have been blasted and powder coated, but I forgot to order the seals for the them. I went to order them but the appears to be a few different types listed. They are the standard 6n2 gti ones which are aluminium. I think they are 38mm?
My problem is that the new shiny powder coating has smoothed over all the markings because it's so thick. I have no idea if they are made by Lucas, ATE or TRW. Can anyone please confirm what they are?
From reading on several other forums it appears there is a good bit of a difference between the various makes.
Also, I have tried to use the old seals (piston seal and dust boot) to see how it goes back together and I'm stuck. I get the dust boot seated and then the piston meats the spindle and it doesn't turn, I have tried a DIY rewind tool but didn't go on easy and I don't want to damage it.
Any advice on getting it back together?
Front calipers go together so easily but the rears are a bit too complicated :)
Edited by dixy
  • Views 812
Gave biggred a call and they said they are most likely Lucas . They do have 2 kits depending on disc thickness. I order both because I need this sorted a bit quicker now.
Any advice on fitting the things?
I've never taken a set of rears apart but I have changed pads on them. I'd highly recommend getting a proper rewind tool to turn the piston back in. The ones I've done have always felt quite tight.
Something like this http://www.ebay.co.uk/itm/BRAKE-CALIPER-PISTON-REWIND-WIND-BACK-TOOL-KIT-22-PIECES-car-service-tool-/181620441470?pt=LH_DefaultDomain_3&hash=item2a496c017e
Similar to what I use and I've had it for 4 years and its never let me down
Thanks for the link, that seams quite a comprehensive kit, I will get that I think.
I was hesitant to get another basic rewind tool because I know I have it somewhere and I can pretty much guarantee it will show up as soon as I get a new one. But that kit looks to do all sorts of callipers so will be worth having around, plus it's in its own box so won't go hiding so easily.
I had another go with the old seals earlier and I reckon if I used the proper tool it would just twist on as the shaft has a kind of thread on it.that said on one side it went on pretty much by hand so I guess that seal is shot.
I won't be doing this again in a rush :(
Thanks again buddy.
