Indicator Stalk Cover Removal
Is there any easy way to remove the end cover on the indicator stalk. The symbols on the ones I have (as you can see) are quite worn - is it possible just replace these parts without replacing/taking out the whole stalk?
I've had a poke around with them and it looks like they could pop off, but I didn't want to pull as the may well be glued in. Anyone had any previous experience with these?
  • Views 1.3k
Just had a quick go at this since I was bored and had a spare set of 6n stalks laying about.
They seems to be held on by little tiny clips.
Being careful with a little flatblade screwdriver should see them free.
As for replacements there doesn't appear to be a part number on them as such so I'm not sure.
That's good to know - I did suspect they might be removable as they appeared to be separate from the actual stalks - but I didn't want to trash mine trying to find out.
I was going to have a look around the local car breakers as I know they have a few Polos, hopefully the indicators are in better condition than mine.
