strut brace help
Okay so this might sound retarded but how do you fit a strut brace to a 2f? Thanks in advance.
Its a front top one.
  • Views 548
Please help
You need to remove the suspension legs so that you can drill holes in the turret tops to mount the base plates. You could bolt them on, or to make life easier in the future weld nuts to the inside of the turrets so it can be removed without the ballache of suspension removal.
