AFH with a top fill radiator
Is anyone running a top fill rad with an AFH, or AVY?
IF so what rad hoses do you use?
  • Views 959
Wouldn't it be the same hose setup as a normal rad, just a different thermostat housing/blanked off expansion bottle port?
get a fiat brava rad, then you can use the same hoses, block the overflow and loop the small one that tees off into the expansion back onto itself
