affordable headlight relay looms spotted
  • Replies 21
  • Views 1.4k
Jesus that is cheap. You'd struggle to make your own for that price
yeah exactly ..even if you buy a spare one its dirt cheap for what results they give
Woah, something useful I can afford :D
Also I know nothing about looms. Is it literally just unplug old wires & connect the new ones?
Almost - you'll need to get 12V from battery and find a good earth point too.
imagine it would take the power and earth direct at the battery terminals , otherwise you can use the alternator+ post
It's cheap but you could say it's cheap for a reason. Personally I would be worried about the quality components used and how it was made. Last thing you want is to watch your car go up in flames due to trying to save a small amount of money. How ever it could be amazing :)
Up in flames! eek!.
Wonder what Christian thinks of the wiring quality?
Driving in the dark with no headlights is the more likely failure mode - but I've got thirty year old relays rated for maybe 100,000 operations, so covered maybe one third of average lifespan already.
I suppose I'm more concerned that some poor bastard made this and the relays with non-RoHS solder in bullied Shenzen factory environment.
I've ordered one nonetheless.
worst case fit some german relays
no worse than the home made dross you see on forums and ebay for 30-40 notes , its only a bunch of wire and a couple of relays anyway
almost everything comes from china now , ipads , headunits , tv's they tend not to burst into flames
Zoom on the relays in the listing and they are type 208 and rated 80Amp. Looks like they even have a resistor and LED to prevent coil burn and show operation. Might be better than german?
yeah anyones guess really
worth a punt anyway...maybe tailor the wires to suit a bit and fit new rings
id take the feed from the alt + terminal to keep it short
Thanks for the heads up
Those relays are poop, they seem to suck in all moisture even where there isn't any.
The rings seem like the crappy flimsy type.
Wiring seems thick enough but could just be thick insulation.
So, may need to swap relays, but that's £10 for a good quality pair, and fit some decent ring terminals and maybe even go over all the other joints.
But all that aside it looks to be a lot of work for the money.
I have ordered 5 just in case :)
Oh yeah I forgot about the inner spots. Never mind - I've got a soldering iron.
Mine arrived today. Relays are not transparent but marked HID H4458 40A-12vdc
which I think are made by FTD -they appear sealed against water ingress.
All looks and feels well made.
Is the listing a pair or do I need to buy 2?
the link is enough to run 2 h4 headlamps
The live looks the right length to reach alternator +ve and the ring fitting looks like it might be 8mm - but I've got a Lucas plug not a terminal in my early alternator.
I don't think the red supply lead will reach starter motor - and might nor be best place.
So new fat wire from the battery +ve to the new light wiring?
(been thinking about new fat wires from alternator anyway at stevo3002's suggestion)
yeah sounds like you have no choice but to run it up to the battery if you have the multiplug alternator , just make sure its well secured so it cant chafe on anything sharp .
But Ipads etc arent on ebay for a fiver : ) theres no way I'm putting that thing in my motor.
Grommet through the bulkhead obviously. I'll mount it near offside wing where not too wet. Not in the motor.
Alternatively you can buy the Rayne headlight wiring loom - or construct one yourself from Linn loudspeaker cable and GEC Plessey telephone exchange relays.
if it reaches theres space up near the horn
