6n de wiper
Advice on how to de.wiper the rear please?
Regards
  • Views 739
You lift the tab up on the rear wiper (where the water jet comes out)
Remove the bolt on the outside and take the wiper off
Remove the rear boot panel
Remove the 3 (i think) bolts that hold the wiper motor on.
It should then just pull off.
My 6ns one came off dead easy but then I did it on my harlequin and it was seized on!
TIP: Get some evo stick to stick the black surround back on as it won't be held on by anything.
Edit: I can't remember if there's an extra bolt on the outside after you remove the wiper.
Edited by vdoubleu
Thanks man how do i remove the boot panel? What could i put in hole? Thsnks
There's one screw in the handle of the boot panel and there's a load of clips on the outside. It can be a bit stiff especially if it's the first time it's been removed.
Most people put a bung into the black plastic trim. I've used a scalextric wheel :lol:
