Sunroof problems on 2002 1.4 TDI SE PD
Hi Group,
I have a problem with the motor on the fabric sunroof on my recently bought car.
The guy told me the sunroof no longer works which i thought was fine and could be repairable.
He handed me the motor, gasket and two screws.
The motor works fine and drives fine with the command button, the problem i see is the teeth on the cog of the motor are not sharp and visibly the teeth on the drive brass cog in the ceiling are worn too.
How can i get the roof open to try and replace the brass cog or un-seize the roof which it could be too?
The two motor mounting screws do not locate and thread either and looks like there are no threads in the black solid bar, are these nut and bolt or threaded inside the black frame.
I really hope someone can help me out and has come across the same problem.
Many thanks in advance.
Gavin
  • Views 708
I've not worked on a polo fabric roof but I have on other cars. It sounds like the motor has tore itself out of it mountings, hence the screws not going back in.
I remember seeing a repair kit on eBay with the gears and cables etc.
screws / bolts wise you can either use some kind of rivet nut or similar, or use a thicker screw.
Is thee an Allen key way in the motor? There is usually a way of opening it. But I imagine it's on the motor itself like the glas roof.
On some cars in this state, it's common to cut the cables to open the roof for repair, then obviously fit the new cables and gears etc.
Also, it is possible to drop the entire roof our as it is a cassette type, but there may be some type of seal or channel holding it from the top.
