Entering a MK2 Polo in a classic trial
Has anyone entered a polo into a classic trial like the ones run by the MCC (Exeter, Lands End and Edinburgh trials). These are endurance trials with observed off road sections.
My polo is far from show worthy, it's not lowered and is pretty much standard. I don't think I have the time or patience to give it the attention it deserves to make the paint work look good so I've decided I should have some fun in it. I'm thinking due to how light weight the car is it wouldn't be too bad off road (tracks).
Just wondering if anyone has done anything similar and have any tips or stories to tell?
  • Views 561
Never entered anything, but I've used standard height mk2's of road quite a bit, often with a half tonne trailer behind and they're really good at it for what they are. Only real tip I can give is use the cars size to your benefit, you can be really accurate with where you put your wheels, so work around obstacles. Make sure you've got a good clutch cable as you do have to use a bit of slip if you want to keep it smooth.
Thanks for the insight! When you say good clutch cable do you mean a new one as opposed to an older one where the cable might have stretched a bit?
