Mk2 Golf ABF 16v, SWAP for mk2/f GT/16v/G40
Year: 1989
Mileage: 167k
MOT: Dec 15
Price: £2500
Basic spec is:
1989 GTi, 166k, 11 months MOT.
ABF conversion.
When i bought it, it was on the original 8v engine, lowered on FK AK coilovers and everything was mainly stock and old, so most of the following spec has been done recently.
Engine
ABF 2.0 16v from a SEAT cordoba on around 90k running the 02a ABF box
Freshly serviced, plugs, leads, oil filter and air filter are brand new.
Ran up to temp with fresh oil and filter, drove 6 miles and then drained and replaced oil and filter again so the oil system is nice and clean!
VW spec inlet manifolds cleaned, blasted and painted
Just about every important gasket changed, headgasket (and bolts), rocker, inlets, exhaust, sump, front water flange.
GTD airbox
Brand new LUK clutch, brand new cable, running the SEAT hydro/cable converter
MK4 02j shifter, cables and tower
Brand new speedo cable
Brand new G60 spec gearbox mount
Solid T-mount Front engine mount
Standard manifold and downpipe into a custom decat pipe, straight into the standard 8v system. Makes a nice sound!
Chassis
FK AK Coilovers, ride and handle brilliantly!
Brand new track rod ends, balljoints
SilverProjects adjustable top mounts
MK3 subframe with standard ABF rear engine mount
Powerflex front wishbone bushes, R32 solid rear wishbone bushes
23mm G60/Ibiza cupra spec front ARB with powerflex inner bushes, recent links
23mm ibiza cupra 'stubby' master cylinder, all front copper lines replaced, and both front flexis
Brand new ATE 9" servo (irritatingly expensive)
280mm G60 front brakes, plenty of life left
standard rear GTi disks and beam
Corrado 'skinny' 16v driveshaft
G60 steel wheels 15x6, brand new Nexen N6000 tyres
Front jacking points welded for last MOT, relevent cavities were cavity waxed and any welding undersealed.
Interior
Standard 8v GTi interior, fairly tidy, not perfect
Headlining is really good
Leather corrado steering wheel
Just replaced dash with a half decent uncracked one
Standard 8v clocks. MFA works as it should, speedo is working with the 02a box!
Heater works as it should, makes irritating intermittent noises though
Kenwood I-pod head unit
Wiring for Sub in place
Speakers are JBL all round by the looks of it, apart from the tweeters
Parcel shelf is good
Exterior
A bit tatty, but for the age of the car and mileage, it's to be expected
Various car park dents and dings
Only real bad visible rust is on the bootlid which is past it's best, have a cleaner non GTi replacement which can be included.
Most of the plastics have been scuffed in one place or another
Dent in O/S sill, hasn't even broken the vinyl though, so no rust starting there, will just need pulling out
Bottom of the wings have gone, not visible really, but could do with replacing
Standard GTi red stripe 4 lamp grill, will also include a 5 slat 2 lamp grill
Brand new Osram Nightbreaker unlimited bulbs, with an uprated headlight loom
Photo speak a thousand words though
15005937878_b9e93b58d5_b.jpg89 GTi by Lewis.Hall, on Flickr
15192501755_61493282ae_b.jpg89 GTi by Lewis.Hall, on Flickr
15005735179_ae07c1f066_b.jpg89 GTi by Lewis.Hall, on Flickr
So basically what we have is a completely mechanically sound mk2, it won't want or need for anything for some time! I built the car to drive spot on and put a smile on my face, and haven't worried too much about the slightly tatty exterior. The baton ideally needs to be passed onto someone who is ready to make it look as good as it drives!
Ideally, i'm looking to swap for a mk2 or mk2f polo coupe with a fairly good base engine, GT, 16v swap or G40, obviously willing to take PX for a car of less value (scruffy GT for example)
Cash price is 2.5k
  • Views 1.3k
Popular Days
You wouldn't be interested in a PX with a ole mk2f (Standard 1.3) and cash would you?
