Rear wiper missing a circle/patch 9N2
I'm not sure what is wrong with the rear wiper on my 9N2. I've had this issue now with two wiper arms, as I changed the stock one after it snapped on me. When its on, it seems to miss quite a large circle patch in the middle of the rear wind screen and it's really annoying. Any suggestions?
  • Views 2.4k
It sounds like the spring on the main arm isn't giving you enough pressure to keep the blade flat on the glass.
Bought myself a new wiper blade, see if that works and will come back to this. Thanks for the advice, though, sounds like it may be that.
Is the arm bolting onto the motor shaft properly ie level/parallel ??
Looks pretty flush to me, that's the thing thats confusing me :/
Daft question but is the screen OK no distortion in the glass ??
Sorry for the late reply, but I fitted the wiper blade and its still doing the same, so therefore must be an issue with the pressure in spring. Just thinking could it be anything to do with the way I fitted the new wiper arm?
