Rusted screws/bolts
So I wanna get LED numberplate bulbs and so, but I'm not sure if the bulbs have been changed since it left the factory. As such I think the screws on the covers are more rust than metal, one of which the head just about disintegrated under the slightest pressure from a screwdriver (and I did remember to drown it in WD40 beforehand). Same problem with the bolts on the bumpers, and the inside plastic trims on the floor by the doors. Best thing to do here?
  • Replies 9
  • Views 995
First tip from me would be to make sure you use a good quality screw driver and one that is the best match for the head of the screw. Too big or too small won't give you the purchase you need and is just asking for trouble.
If you round the head off but there is still some metal there then you could try and hammer in something like torx bits from a socket set (again good quality) and hopefully that will free the screw.
Last option, if the screw is completely gone is to get handy with a drill and drill them out.
I cannot stress enough how much good quality tools make a difference when it comes to working on old rusted bolts. I learnt this years ago when I was trying to take off an arch liner with a cheap and nasty B&Q socket set. I just couldn't get enough purchase on the bolts and was destroying the heads. My mate handed me a Snap-On socket the same size and they all came right off. Not suggesting you spend your life savings and buy Snap-On but just don't buy cheap.
yeah good tools often help no end , so top quality screw drivers and 6 sided sockets
irwin bolt grips are great for rounded bolts
for screws that are wrecked drill the head carefull until its gone , the part should them come off and use vice grips to turn the remains
i tend to replace stuff like that with stainless so it wont rust again , just dont use stainless on stuff like brakes or suspension parts , and put a dab of copper grease on the threads of whatever you fit
it is said if you put a rubberband over the head then screw it, you'll get the grip you need. also use a small stubby screw driver and lots of pressure to keep it firm
theres also left handed drill bits which sometimes will spin the screw out as you drill
Sounds extreme but get a flat head and hammer it in the old slot so makes a new slot and that might be possible to undo if not try and cut if off, or remove the bumper and see if can take off from inside, sorry I can't be much help but drilling would be the best idea but need a good drill which costs
Try taking the panel off the back of the boot. I did this when I had the same problem. Did I get a mole grip on the thread? Can't remember. Anyway it worked.
A good soaking of plusgas will help too.
Tighten very slightly first. That way if you munch the head up breaking the rust seal, you've not knackered the side of the slot you're going to need to undo the screw.
An old-school impact driver like this can really help with bad screws:
Clobber it with a big hammer, and the mechanism makes a small turn (you can set it clockwise or anticlockwise), while the impact of hitting it makes it dig in. It's worked really well for me on a few occasions when I just couldn't get enough force behind a screwdriver to stop it slipping. Brilliant for those stupid little retaining screws on brake discs too.
