frozen locks
Help! No matter how little the frost, the locks on the front doors will not open. The central locking engages,and the buttons pop up,but I cannot open the doors. I normally have to go in through the back doors and climb over. Really embarrassing at my age. Once the car is warmed up, things are fine. Any thoughts on a cure would be grateful. :help:
  • Replies 11
  • Views 905
if you cant turn the key ok try putting some oil on the catch mechanism on the side of the door.
As I said, the locks open,the buttons pop up, but the doors stay shut. I have put de-icer all around the doors and seals to no avail.
Is it the door freezing to the rubber door seal ?
Sounds that way. Wipe them dry and spray some silicon lubricant (or the cheapest furniture Polish you can find) onto the door seals.
I did this to the derv of doom-makes a big difference:)
Last winter I had exactly the same problem, I took the lock mechanism out of the door, dried it in the oven then sprayed liberally some "151 HI-TECH super grease" into all parts of the mechanism and since then no problems :)
Thanks All, I shall persevere and try all different ways. My thinking is that its the locks freezing,so shall do the oven roasting and see what results are. :smile::smile:
Also look at the seals as mentioned aboove. No harm in a quick wipe of some silicon lubricant, you would be surprised how tough it is to open those doors when the seals have frozen 3/4 of the way around the door.
I've had this happen on mine several times. More so when theres been a frost during the winter, but also during summer first thing in the mornings. All the doors would unlock and open fine, but drivers door wouldn't open for a gold cow.
Exactly the same issue as yours, even on slightly frosty mornings. I too, access via back doors - somehow or other they don't suffer from this problem. I wonder why?
The pop-ups rise; the outside and inside handle/s work as normal, but still the catches won't release. When the inside warms up - doesn't take long - all returns to normal.
To clarify: what part/s are given the "oven roasting" treatment?
Edited by fabcam
Sorry for delay,no have not had time yet. Work commitment and weather. :sorry::sorry:
