Breaking Hi Spec G40 1341 BVH Turbo Conversion 200BHP
Unfortunatly it has come time to part and move on from the G40 :o
ED5995F1-567E-49B4-8B62-4E4B7C6EBE2C_zps
I have had 6/7 years of fun with this car and have come to a point where i know the car inside and out!
Seems a shame to break it, but the amount of money sitting in it, this is the only way to get half of the money i have spent on it back!
Why am i selling?
1. I love to learn about cars she owing and feel i know this inside out and cannot reap any more performance without spending more £££££££
2. I have bought a house which is a huge project, shit has just got real and need a semi sensible daily driver that isn't going to cost me stupid money.
Unless you have £4500/5000 to spend don't ask me if i will sell the whole engine as a conversion because the answer will be no
About the car/engine
I haven't had the car rolling roaded yet, it's current set to 20 psi but is good for 22/23psi with the K03 073
Should see anywhere from 190-210bhp
I have just been to Santa Pod and achieved 13.9 on road tyres
Off the top of my head
Spec and prices are as follows;
1341 accrilite Pistons, rings, bearings etc -£1000
Turbo setup £1200
k03 073 (from the 190 audi, rarer type, basically a k04) (Turbo smokes from cold but is fine when warm needs seals looking at)
Rothe manifold
Stainless down pipe
PSD turbo cam
315cc injectors
Dump valve
Ecu with larger map sensor and chip mapped by Andy (PPP)
PSD Big valve head (checked over by man in the shed) -£400
51mm TB- £100 provisionally sold
G40 gearbox with quaife diff -£650 Provisionally sold
TCA Rose jointed - £100
PPP Exhaust £200
Uprated driveshaft £150 provisionally sold
Stage 2 PPP subframe -£200
Uprated alloy radiator with slimline fan £200
Intercooler and hoses £100
Gaz Coilovers recently serviced £400 provisionally sold
Ta Technics Coilovers £300
Helix 4 Paddle Clutch - Only covered 1500 miles maximum £150 provisionally sold
Flywheel x2 £50 each
Fuel pump etc £50
G40 Seats - £100 provisionally sold
G40 Shell £300 - Needs Work! ask for more info
I also have a mint Black engine is out and it has no exhaust, (still has MOT) i bought it to re shell my g40 but now obi plans have changed) -£500
Smoothed Rocker Cover (fig welded) £100
Wheels Mattig Steels Brand new tyres £400
Any info wanted... please ask..
Check out my build thread if you want....
Car is located in Rugby
Rich
Edited by XRrich
  • Views 2.1k
  • Also have all the other bits from a g40 G40 rear beam Loom G40 Clocks Steering arms Brakes with drilled and grooved discs and new brembo pads braided lines Injectors 315 cc g40 dizzy and anythin
PM'd
G40 rear beam
Loom
G40 Clocks
Steering arms
braided lines
Injectors 315 cc
g40 dizzy
and anything else you can think of
Edited by XRrich
How much for the clocks posted?
Pm'd
What sort of condition is the rear beam in mate?
Looks fairly decent mate, corrosion but nothing major
I'm after some VW11'S if you got em and the rad but £200 sounds a bit steep for an ebay one.
