Door handle armour plates
Hi guys, i am trying to fit door handle armour plates to my breadvan but when they are on the screw thread does not line up with the hole in the door shut. This also happened on my other breadvan. its looks like the handle needs to go in more.
has anyone else had this problem?
thanks
  • Replies 8
  • Views 854
yeah they can be a bit alkward to fit , I've just pushed on the handle hard to get the screw started
mine were genuine ones though
Yes, I had exactly the same problem. Had to oval the hole in the edge of the door and also space out the door lock/unlock flipper on the lock barrel so it still 'reached' the right places!
Right pain in the arse. I have new doors to go on, so won't use armour plates again.
A lot of work to fit on an 86c, compared to a mk1,2 or 3 Golf, which was easy. The instructions tell you to elongate the holes in the door skin.
I knew armour plates required work to fit. But i robbed a set from a scrap Mk2 Golf at a breakers yard a few years back, they moved the handle out so much i always assumed Polos required a different type. Am i wrong then?
No, same part.
If i hold the handle in place and operate the handle, it slips off after a couple of pulls. then doesn't lock properly??
You're supposed the take the 'gasket' off the end of the handle, that's what allows the handle to sit further in
I did take the rubber gasket off but still sits too far out
