Polo 86c electric headlight adjusters
bought but never used, making the loom is not beyonde me
£45 posted
  • Replies 8
  • Views 556
Guessing this is for a mk2f?
yeah they are
Woah, so they do exist :shok:
How much would the loom be as well? And is there anything else needed to fit this to a standard Mk3 setup?
it'd be a case of having the loom fabricated using the connectors in the sale
You only need a single wire (red/blue wire) from the dash control to the headlight motors, the supply (yellow wire) is from the dipped beam and a ground (brown wire) then at the dash control you need the same yellow wire to the dipped beam from the column switch, a ground brown wire & a backlighting supply grey/blue wire
standard fit in europe , I'm sure you could find a loom on ebay.de
SOLD
