POLO OPENAIR 1.4 CL 8V 3dr sale again £400 ovno
Year: 1999
Mileage: 89000 ish
MOT: April 2015
Price: £400
I brought the car in 2010 with 65000 miles on the clock for a lady owner, I am the third owner from new. However it wasn’t driven very much 5 miles every other day. The breather was all blocked and the tappets where noisy. I fixed the problems and the car has served me very well but it’s time to move on I’m in need of some funds to purchase a 5 door car.
Very good on MPG and has been unmolested. I have serviced the car with good quality parts and oil.
Make: VW
Model: POLO OPENAIR 1.4 CL 8V 3dr
Year/Reg: 1999 T
Mileage: 89000 will go up slightly
MOT: April 2014
Tax: 10/2013
Good points:
8 new tappets fitted at 65000 miles,
New Oil separator (Oil Breather),
Sump cleaned and resealed,
Oil pick up cleaned,
Head gasket, valve stems oil seal, valves ground removed carbon build up and timing belt done at 75000. Due to valve stem oil seals being dry and crack,
Rear brake pipes change for MOT 2012 (copper and rubber)
New Windscreen fitted last year, MOT 2012 sush a difference with no scratches.
New Sachs Clutch fitted (27/07/13) See picture
New Fly wheel, fitted (27/07/13)
New Bearing Sleeve (2707/13)
New Starter bush (27/07/13)
New back box fitted last year,
New thermostat housing and thermostat 2012
New Temp sensor 2012
Rear arches are in good condition i treated it with krust to help stave off the dreaded rust.
MOT:
19/04/2013 83779
24/04/2012 79540
29/04/2011 65512 I owned the car from this MOT
31/03/2010 60296
Bad points:
Bad points:
Small rust blister on drivers door skin. See picture
Small dent in bonnet,
Slight rust under fog lights,
Few car park scratches and stone chips,
The starter motor is a little noisy, was thought to be a damage fly wheel on inspection starter bush inside gearbox had broken, was removed and new bush fitted. Starter slightly noisy because of the bush being broken, car starts fine, read worse than it sounds.
Rear bumper has markers from previous owner unloading push chairs from boot,
Dent in rear valance near exhaust (from previous owner)
Trim under front light has broken clip on passenger side,
Front fogs light fitted by previous owner but never wired in.
Passenger door spline broken but on order and will be fixed before sale.
Pictures:
Price: £400 ono
Currently sits on Standard 13inch polo wheels with 185/65/13 tyres
I can take any photo you want and answer all question.
Contact details: Club polo Email or text 07595703255
Edited by residentmelon
  • Replies 8
  • Views 770
Updated photos with alloys
Any leaks from the sunroof or anything? gearbox all ok? would you be willing to get a new mot on it for me, bit cheeky i know but i need something i don't want to have to worry about while my other cars are off the road.
thanks
Liz
thanks
Liz
I can have a look at putting a MOT but anywork carried out i have to put the price up a little to recover the cost. it depends on what it is. It should be alot though.
Gearbox is fine changed the clutch and only use it on the weekends and when i can't car share with the girlfriend. The last big run it had was three trips to Sheffield and back for site work three weeks ago.
The only time I had it leak is when I park it on my mum's drive for about two weeks and the car was facing down hill and the water collected in the wind deflected and came in a little.
I just regresed the runner on the roof to make it open more smoothly.
The only thing I would do is change the tyres as i don't like them they have tread and legal i just don't like the ride.
MOT 19/04/2013 83779 since this MOT i'm now currently on 89300 miles two years i've only covered 6000-7000 miles
So as you can see i don't use it much which is a shame.
no thats fine, its just i'm hopefully getting bluey back around then and i can't be dealing with sorting out something else! does it come with the alloys or are they extra?
Comes with the alloys
Ok cool, let me know what you think about putting a new mot on it, to be honest I would be interested otherwise.
Hi is this still for sale?
HI all
I drove the car to the Airport left if for a few days to come back to the mid section of the exhaust blowing really bad it's sound like a 1 litre Corsa with a huge exhaust. I had to pretend it was a V8 and smiled. it was funny when I pulled along side an Subaru Impreza and revved my engine. me and the other drive busted out laughing.
Due to the few things wrong and now the exhaust it's not fair to pass it on too the next person.
So the car will be broken at the end on the month. Shame as the shell is pretty solid with little rust on the rear arches.
Look for a new Advert soon
Martin
Moderator: Please lock or delete this post thank you.
