my 9n3 project need suggestions on what to do next
right so currently i have:
fitted 30mm lowering springs (no intention to slam as not practical to where i'm currently living ): )
16" plum purple rx2 bbs splits
flyeye headlight tint
yellow headlight bulbs
pink sidelights
yellow tint on fogs
purple interior footwell lighting
gti honeycomb grill (soon to be coloured coded with alloys)
stickerbomb decal
my next step is to get 10mm spacers and splitter (fake lows!) and to colour code interior with alloys.
running out of things to do next. suggestions would be highly appreciated! :D
post-919668-0-61284300-1422965679_thumb.
post-919668-0-93760800-1422965684_thumb.
post-919668-0-40020900-1422965690_thumb.
post-919668-0-79254200-1422965695_thumb.
post-919668-0-91707600-1422965700_thumb.
post-919668-0-34195500-1422965705_thumb.
post-919668-0-68582500-1422965707_thumb.
post-919668-0-25538200-1422965710_thumb.
post-919668-0-45473900-1422965714_thumb.
  • Replies 11
  • Views 2.2k
Since you've asked for opinions, next thing would be to take it back to standard
Honeycombed lower grills debadge the back end a smaller Arial
alright, no need to be harsh! and i asked for suggestions.... not opinions so if you dont like it dont comment. simple.
i have the lower grills, but i can only get the drivers fog grill off... the others wont budge :@
and thanks :))
You asked for the suggestions.
But to explain, to me it's a confused look with a lot of colours, yellow lights, pink (illegal?) sides and purple wheels with grey body work and red stripe. Would you wear those colours at once? I'd look at maybe sticking with one or two colours to get a coherent look.
But if you don't like that as a suggestion, maybe lower it and think about wider wheels/spacers to get the stance a little nicer
I agree with the 'too many colours' thing. It looks a bit like a unicorn vomited on it, and not in the best way. Maybe colour match the grill to the wheels and swap out the sidelights for yellow ones, as like prankstar said, I'm fairly sure pink are illegal. Whereas the yellow will at least match the headlights. I can't stand people who drive around with yellow headlights personally, but if that's your thing.
Again, just an opinion, but I think it would look much better with less colour clashing.
If you guys read the top it says I'm planning on colour coding it all... Just waiting for the paint atm.
And prankstar again I've already stated I'm getting spacers :)
I'm looking for additional suggestions to what I've already stated I'm getting around to doing. It's working progress as are most projects. Doesn't happen overnight unfortunately.
Sidelights were just a impulse buy, I know they're not legal but they're barely visible with headlights on and I haven't been pulled yet ;)
If you are sticking with the purple theme then I would look into getting purple number plate lights too. Again possibly illegal but should fit in with the theme quite well. I would also see about making the red GTI strip purple too.
Appearance wise there is not much more to do with that other than lowering it more. Adding anything else would just make it too busy I think.
The plan is the make it a purple polo :) it's just taking a little longer than anticipated to colour code it all! And the red strip will go purple asap (when the weather improves).
Ooo I'm liking the idea of purple reg lights!:) might even get pressed plates to accompany it :)
Looks nice! Colour coding looks nice already but when you change the red stripe to purple it will tie it all together nicely.
Only thing I'd suggest is MOARE LOWZ! But as you said it's not very practical. You'll go to a few shows though and be buying coilovers before you know it!
Yeah, as I said, colour coding will work a treat. I like the body colour and I think it would look good with purple trim. :) will look nicer once the grill is done!
