Heating
Hey all
My car had not been started for 2 weeks as i was changing over the driveshafts
I have got it all sorted and started driving it today , however the heaters are not warming up at all i drove for just over a hour and still no heat :/ :(
Any ideas please ?
Thank you
  • Views 571
Was the water temp gauge sitting at 90 like it should or was it showing nothing?
Check your coolant level is ok then run the car up to temp while it is sitting. If it gets up to temp while sitting but still no hot air through the vents then you may have an air lock in the water system.
If you do get hot air then it is likely to be something to do with your thermostat or thermostat housing.
Its showing 90 thats why i got so confused but thank you ill have another look and see 👍
